1. Does anyone know if BTB lances are supposed to commonly break in AD&D (say on a hit during a charge, a little like the 1E Arrow). This seems to be what would happen when used in combat IRL. I realize jousting lances (in tournaments) where likely made to break on impact to lesson the chance of injury to the opposing knight. But what about when used in combat? Right now, we don't have lances break (since its not mentioned as far as I can see).
2. Do you think the rider must drop the lance after they hit their target in a charge (or do you allow them to pull the lance out and attempt further attacks.
I found this on a military weapons website, not sure how accurate it is. Maybe P&P, Matt or Sean (or someone else) might have some info based on re-enactments or historical knowledge?
Jousting Weapons - The Jousting Lance used in combat
The purpose of the jousting lance used on the battlefield was to unhorse a rider or penetrate the armor of an enemy knight
The lance was long spear-like weapon, made of wood. The jousting lance was used in the 'couched' position, held close to the body, while mounted on a charging horse
The jousting lance was made of wood, usually ash, with a metal tip made of iron or steel. The lance measured from 9 to 14 feet in length and 1.5 inches to 2 inches in diameter
The jousting lances were tipped with a coronal. This was a crown shaped metal cap consisting of three or more blunted metal prongs. The purpose of the coronal was to allow the lance to catch and hold on to the shield, making it easier to unhorse the opponent, or break a lance on him.
Jousting Weapons - The Jousting Lance used at tournaments
The Jousting Lance used at tournaments were designed to reduce the number of potential injuries to the knights. The purpose of the jousting lance used at tournaments was to unhorse a rider in single combat, such as in the "joust for peace"
The vamplate was added to the lance to protect the hand. It first appeared as a small protective disk but grew to a conical shape by the 14th century. The vamplate was seldom used in warfare
The lances used at tournaments were not fitted with the metal 'points of war'
Jousting Weapons
Jousting Armor
The Jousting armor used during the Middle Ages varied according to the financial status of the knight. Jousting armor was extremely expensive, as was the conventional suits of armor, so many knights only owned one suit of Knights armor which was used for battle and for jousting armor. Jousting Armor was developed specifically for the joust. This type of armor had heavier protection on the side toward the opponent and lighter or no protection on the other side. Another style of Jousting armor had a built-in shield on one side of the waist, just at the point where the lance should strike. Other types of Jousting armor was designed to break apart on impact, leaving the rider in the saddle and reducing the possibility of injury. A jousting helmet called a 'frog-mouthed helm' was a specific piece of Jousting armor. The helm had an eyeslit at the upper part of the helm, so the knight could lean forward to see, but straightened at the moment of impact so the lip protected his eyes from splinters. This was an extremely useful piece of Jousting Armor as many, often fatal, injuries were sustained by knights - the eye of King Henry was pierced by a sliver that penetrated the brain, from the shattered lance of his opponent. This event is detailed in the section relating to the History of Jousting. The lance was used as the major weapon in jousting. The jousting lances were tipped with a coronal. This was a crown shaped metal cap consisting of three or more blunted metal prongs. The purpose of the coronal was to allow the lance to catch and hold on to the shield, making it easier to unhorse the opponent, or break a lance on him. A lance rest was protruding arm attached to the breastplate of the jousting armor to take off some of the weight of the lance when jousting.
