Forum Picture
JRMapes
Old School Games
Post by JRMapes »
Turgenev wrote:I would darken the blacks on the image to match the top part and the background of the site. Like so...
Cheers,
Tim
something like that works. however you cant get away with just using the paintbucket feature or a color swap. he background grey is also in some of the people in the drawing, you black out those parts in the people in the "mass" change.
THe only way to do it is by hand so you dont contaminate the individuals and objects.
[color=red][b]UPDATED[/b][/color] [size=75][url=http://jrmapes.livejournal.com/][b]The Web Between Worlds[/b][/url] - My LiveJournal - Personal and Gaming News.
IMTU: JR Mapes 0309 C38A975-D S tc++(**) ru+ tm+ !tn t4 tg- t20 !rtt ?t5 ge+ 3i++ c+ jt- au ls+ pi+ ta- he+ kk+ hi++ as++ va dr so+ zh da++ vi+ 633
[color=yellow]TRAVELLER INFLUENCE[/color]: "No other rpg except D&D has influenced current gaming more than Classic Traveller." [i]- Kellri[/i]
[color=yellow]GROGNARD GEARHEADS[/color]:"Building anything for Traveller is a blast. Just make sure you've got a spreadsheet and a college education. Traveller is built for REAL MEN. There's none of that freeform prose for pussies you'll see in other games." [i]- Kellri[/i]
[color=yellow]THE DUNGEON GESTALT[/color] - D&D is primal fetishism. It makes relics out of old character sheets and totems out of a stack of hardback rulebooks. The dungeon crawl itself is a ritual with no obligation to make sense beyond the circle of participants. In that sense, it's a lot like a cave painting of some ancient hunt. It's a convergence of random events in a controlled setting that forms the basis of a heroic tale in the minds of the participants. Powerful and primitive social magic that can't be reliably explained but only experienced. And IMO, a much more 'real' experience than the forced plot you see in most 'storyteller' games. [i]- Kellri[/i]
[color=yellow]GAMING-Back To The Basics[/color]:"It was a helluva romp in the 70s. The choices were D&D in the white box, Traveller in the black box, or if we wanted something really bizarre, Empire of the Petal Throne in the colourful box! ...You know... it's stunning. Between them, those three games cover so much ground, everything since has been footnotes and elaborations." [i]- pyratejohn[/i]
[url=http://knights-n-knaves.com/][b]Knights & Knaves[/b][/url] OD&D/AD&D/Traveller/Battletech/
[/size]
Turgenev
Post by Turgenev »
JRMapes wrote:something like that works. however you cant get away with just using the paintbucket feature or a color swap. he background grey is also in some of the people in the drawing, you black out those parts in the people in the "mass" change.
Using Photoshop, this is how I did it... create a new layer above the original one (lets call it layer 2). Paint all of layer 2 black. Turn off the visibility for layer 2 and go back to the original image (layer 1).
On layer 1, select the areas that you wish to darken. I used the Magic Wand Tool with a low Tolerance of around 20. Use the 'add to selection' option to add more areas or the 'subtract from selection' option to subtract from the selections as you see fit. The same can be done with any of the Selection tools like the Polygonal Lasso Tool (which I find extremely useful). As for the people, I would leave the black on them alone for the most part (unless it melds with the background).
Once you have selected the area that you wish to darken, then inverse the selection (this means the areas not selected have become selected instead). Click back on layer 2 (which will make it visibile again). Hit delete and the inverted selection will disappear leaving the black on the spots that you originally selected. By doing this on a new layer, the original image is unchanged (in case you wish to do some tweaking). You can also adjust the Blending Option on Layer 2 to make it a bit transparent to get a better blend.
How much time you want to spend tweaking the image to get the blacks right is up to you. I spent maybe 10 minutes doing the image that I posted earlier (that you quoted) but I was doing it quick & fast.
'Save for web' to get a nice web-friendly jpg/gif/png (this compresses the image & all layers). I recommend saving the file as a psd file as well since it will keep the layers for you (should you wish to make changes at a later date). Actually I know the current image is a gif file but jpg are much better for colours. IMNSHO, gifs are only good if you want to do transparent backgrounds (and even then png files are better unless you're using IE).
Photoshop is a wonderful tool. :)
Quick Edit: When I say 'you' in this post, I mean it in the general sense and not JRMapes specifically. ;)
Cheers,
Tim
Mordenkainen
Post by Mordenkainen »
:shock:
I never thought I opened up a can of Giant Dire Worms with this thread! :lol:
If I keep fiddling with Photoshop the boss is gonna start sniffing around. :wink:
Gentlemen, you can't fight in here! This is the War Room!
Why not use the original image "as is" with the newer text? If that's not possible, how's about 2 images? Use the original drawing as the bottom image with the newer text as top image. Both can point to the .php link.
northrundicandus
Blood and Souls for Arioch!
Post by northrundicandus »
Any chance I could get our current forum graphic redone without the picture below, with just this text:
Knights & Knaves
with K&K still in the background?
Several sizes would be neat too. I need them for the new K&K homepage, and my photoshop fu is quite weak.
I've grown quite fond of the current forum graphic. The scanned picture below the current graphic has this grainy silent film vibe that I really like now.
